You can update an existing VRF for a tenant.
You can update a VRF before or after you create an EPG. But, the VRF will reflect on the switches only after you create an EPG.
efa tenant vrf update [--name vrf-name | --tenant tenant-name | -- operation code |--local-asn local-asn | --ipv4-static-route-bfd route | --ipv6-static-route-bfd route | --ipv4-static-route-next-hop route | --ipv6-static-route-next-hop route | --max-path unit |-- redistribute {static | connected} | --rh-max-path {8 | 16 | 64 | 128 } --max-path {1-128} | -- rh-ecmp-enable= {true | false} | --graceful-restart-enable= {true | false } | --routing-type {distributed | centralized }
For more information on syntax and command examples, see the ExtremeCloud Orchestrator Command Reference, 3.6.0 .(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation local-asn-add --local-asn 75001 WARNING : This operation will result in the reset of the backup routing bgp neighbours of the VRF. Do you want to proceed [y/n]? y Vrf updated successfully. --- Time Elapsed: 7.09160915s ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation static-route-add --ipv4-static-route-next-hop 10.20.246.6,182.20.0.0/24,11.11.11.1,5 --ipv6-static-route-next-hop 10.20.246.5,1010:30::1/128,1001::3,5 Vrf updated successfully. --- Time Elapsed: 244.090637ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation max-path-add --max-path 60 Vrf updated successfully. --- Time Elapsed: 188.793294ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation redistribute-add --redistribute connected Vrf updated successfully. --- Time Elapsed: 225.778861ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation rh-max-path-add --rh-max-path 64 Vrf updated successfully. --- Time Elapsed: 99.141472ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation rh-ecmp-update --rh-ecmp-enable=false Vrf updated successfully. --- Time Elapsed: 173.438931ms ---
(efa:root)root@node-2:~# efa tenant vrf show --name blue11 --tenant tenant11 --detail
Tenant : tenant11
Routing Type : distributed
Centralized Routers :
Redistribute : connected,static
Max Path : 60
Local Asn : 75001
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path : 64
Enable RH ECMP : false
Enable Graceful Restart : false
Route Target : import 100:100
: export 100:100
: import 200:200
: export 200:200
: import 300:300
: export 400:400
Static Route : Switch-IP->Network,Nexthop-IP[Route-Distance], ...
: 10.20.246.6->192.168.0.0/24,10.10.10.1[5] 2020:20::1/128,3001::2[6] 182.20.0.0/24,11.11.11.1[5]
: 10.20.246.5->192.168.10.0/24,10.10.10.5[5] 2020:30::1/128,3001::3[5] 1010:30::1/128,1001::3[5]
Static Route BFD : Switch-IP->[DestIP,SourceIP][Interval,Min-Rx,Multiplier], ...
: 10.20.246.5->10.10.10.1,10.10.10.254[200,300,6]
: 10.20.246.6->10.10.10.5,10.10.10.252 3001::3,3001::1[100,200,5] 3001::2,3001::1 3001::4,3001::1[100,300,6]
VRF Type :
State : vrf-create
Dev State : not-provisioned
App State : cfg-ready
--- Time Elapsed: 59.390211ms ---
On Device1:
10.20.246.5SLX# show running-config vrf vrf blue11 rd 172.31.254.211:1 resilient-hash max-path 64 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route static bfd 10.10.10.1 10.10.10.254 interval 200 min-rx 300 multiplier 6 ip route 192.168.10.0/24 10.10.10.5 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route 1010:30::1/128 1001::3 distance 5 ipv6 route 2020:30::1/128 3001::3 distance 5 ! ! |
On Device2:
10.20.246.6SLX# show running-config vrf vrf blue11 rd 172.31.254.152:1 resilient-hash max-path 64 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route static bfd 10.10.10.5 10.10.10.252 ip route 182.20.0.0/24 11.11.11.1 distance 5 ip route 192.168.0.0/24 10.10.10.1 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route static bfd 3001::2 3001::1 ipv6 route static bfd 3001::3 3001::1 interval 100 min-rx 200 multiplier 5 ipv6 route static bfd 3001::4 3001::1 interval 100 min-rx 300 multiplier 6 ipv6 route 2020:20::1/128 3001::2 distance 6 |
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation local-asn-delete WARNING : This operation will result in the reset of the backup routing bgp neighbours of the VRF. Do you want to proceed [y/n]? y Vrf updated successfully. --- Time Elapsed: 1.162426042s ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation static-route-delete --ipv4-static-route-next-hop 10.20.246.6,182.20.0.0/24,11.11.11.1,5 --ipv6-static-route-next-hop 10.20.246.5,1010:30::1/128,1001::3,5 Vrf updated successfully. --- Time Elapsed: 162.621663ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation static-route-bfd-delete --ipv6-static-route-bfd 10.20.246.6,3001::3,3001::1,100,200,5 --ipv4-static-route-bfd 10.20.246.5,10.10.10.1,10.10.10.254,200,300,6 Vrf updated successfully. --- Time Elapsed: 168.307373ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation max-path-delete Vrf updated successfully. --- Time Elapsed: 117.514104ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation redistribute-delete --redistribute connected Vrf updated successfully. --- Time Elapsed: 202.742522ms ---
(efa:root)root@node-2:~# efa tenant vrf update --tenant tenant11 --name blue11 --operation rh-max-path-delete Vrf updated successfully. --- Time Elapsed: 138.245305ms ---
(efa:root)root@node-2:~# efa tenant vrf show --name blue11 --tenant tenant11 --detaill
Tenant : tenant11
Redistribute : static
Max Path : 0
Local Asn :
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path :
: export 100:100
: import 200:200
: export 200:200
: import 300:300
: export 400:400
: 10.20.246.6->10.10.10.5,10.10.10.252 3001::2,3001::1 3001::4,3001::1[100,300,6]
VRF Type :
State : vrf-create
--- Time Elapsed: 75.948924ms ---
On Device1:
10.20.246.5SLX# show running-config vrf vrf blue11 rd 172.31.254.211:1 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route 192.168.10.0/24 10.10.10.5 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route 2020:30::1/128 3001::3 distance 5 ! ! |
On Device2:
10.20.246.6SLX# show running-config vrf vrf blue11 rd 172.31.254.152:1 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route static bfd 10.10.10.5 10.10.10.252 ip route 192.168.0.0/24 10.10.10.1 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route static bfd 3001::2 3001::1 ipv6 route static bfd 3001::4 3001::1 interval 100 min-rx 300 multiplier 6 ipv6 route 2020:20::1/128 3001::2 distance 6 ! ! |
